Welcome back:
When you say coil, are you referring to the ignition coil housing? Also, if you replaced the entire unit, was the ignition control module new?
Take a look at the pictures I attached. First pic I highlighted the ignition coil housing. The second pic, I highlighted the control module.
If you could, let me know the codes you are getting, if this started all at once, and anything you can think of that may help me narrow it down.
Aug 1, 2019 at 7:26 PM
