Running bad, sounds like it is only running on a couple of cylinders
2001 DAEWOO LANOS
90,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
KAYLA BRITTNEY WALLIS
  • 4 POSTS
My car was running pretty bad. I have since replaced spark plugs the leads and now the ignition coil. I am thinking that the leads may be on the wrong way. Does anyone have a clue on which one goes from spark plugs to the ignition coil? Thanks. Want to double check, it is hesitating bad and just sounds like it is running two or three cylinders.
Aug 5, 2018 at 6:25 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
This is the only picture I found. Hopefully you pressed hard enough down to have them fully seat into the receptacles. If it runs bad enough it should trip the check engine light quickly. If it does that you can put a scanner/code reader on and it will show you if/what cylinders are misfiring. I have attached a link about misfires. Hope this helps and feel free to ask any questions if needed.Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Aug 5, 2018 at 6:40 PM
  • 4 POSTS
Hi, is the firing pattern 1432? Is the coil holes downwards 1432 or 1234?
Aug 5, 2018 at 6:44 PM
DANNY L
  • 5,648 POSTS
Hello again.
The firing order is 1-3-4-2 I have attached a picture. Hope this helps.
Danny-
Aug 5, 2018 at 6:57 PM
  • 4 POSTS
Hi, all seems to be in order. I pulled injector plug out one at a time and three times the idle went down on the far right cylinder. It did not change anything where to from there.
Aug 5, 2018 at 6:58 PM
DANNY L
  • 5,648 POSTS
Hello again.
I would stick and old spark plug in the one cylinder that did not change and with engine running see if the plug is sparking. If not I would suspect a faulty coil. They also make a tool called a 'Noid Light" to hook into fuel injector harness to see if getting a signal. Hope this helps and thanks again for using 2CarPros.
Danny-
Aug 5, 2018 at 7:05 PM
  • 4 POSTS
I had swapped injectors with another one and it worked, but now the one a swapped is not working. So will this be an electrical issues with the plug?
Aug 16, 2018 at 10:58 PM
DANNY L
  • 5,648 POSTS
Hello again
Yes, It sounds like you are not getting an Injector Pulse for that cylinder (electrical). You might have to replace the PCM. That can be kind of expensive. Would you like me to find you a cheaper/less costly replacement? Hope this helps an thanks again for using 2CarPros.
Danny-
Aug 18, 2018 at 2:52 AM
