I had a code that cylinder one the ignition coil was bad
1999 FORD F-250
208,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
BUDDYVEGA
MEMBER
FOLLOW
I went ahead and replaced the spark plug and ignition coil, but it still sounds like it is misfiring.
Dec 12, 2019 at 11:50 AM
BUDDYVEGA
MEMBER
I have also disconnected the plug and turned on the truck and it still makes the same loud noise as if it was plugged in. I assume it’s the ignition coil module but I just wanted to be sure.
Dec 12, 2019 at 12:01 PM
CERTIFIED EXPERT
Good afternoon,
What was the code?
Can you upload a video of the noise you are describing?
Dec 12, 2019 at 3:01 PM
BUDDYVEGA
MEMBER
Hello!
It was a P0351 and P1405.
Dec 12, 2019 at 3:17 PM
CERTIFIED EXPERT
Okay, 1405 is for the DPFE sensor. It could be the hose is off or broken. I attached a picture for you.
The 351 is a wiring issue for the coil. I attached a wiring diagram and highlighted the wires. One wire should have 12 volts with the key on. The other wire is pulsed to ground from a signal from the crank sensor.
Dec 12, 2019 at 3:30 PM
BUDDYVEGA
MEMBER
Would it be best to change the whole module to that coil?
Dec 12, 2019 at 3:35 PM
CERTIFIED EXPERT
There is no module. the control is the PCM. Check the voltage to the coil first.
What about the noise? Can you upload a video for me?
Dec 12, 2019 at 3:43 PM
BUDDYVEGA
MEMBER
I speaking about the specific connecter to the coil. I’m not at my vehicle right now so I am unable but it is very similar to the sound of a bad spark plug/coil.
