Ignition
1997 DODGE CARAVAN
190,500 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
MONSTERCATS
Car died and will not start. Does nothing when turning ignition to start. Starter is good ignition switch is good and relays are good. Fuel pump does not come on and blower does not come on, but the radio does.
Jul 18, 2016 at 1:09 PM
CARADIODOC
  • 34,306 POSTS
Start by measuring the battery's voltage. It will be 12.6 volts if it is good and fully charged. If you find it is around 12.2 volts, it is good but discharged. In that case, charge it at a slow rate for an hour, then measure the voltage again with the engine running. It must be between 13.75 and 14.75 volts. If it is low, suspect the alternator.
If the battery measures around 11.0 volts, it has a shorted cell and must be replaced.
Jul 18, 2016 at 8:06 PM
MONSTERCATS
Thanks for the reply, but battery is good and car wont start. When I turn ignition to start position nothing happens. Lights do not dim, no click from starter or battery, fuel relay does not click. No response from starter at all.
Jul 18, 2016 at 8:43 PM
CARADIODOC
  • 34,306 POSTS
The starter relay is run by the engine computer, not the ignition switch directly. A discharged battery will cause the symptoms you described. Computers do weird things when the supply voltage is low.
To add to the aggravation, the neutral safety switch is no longer simply in series with the starter relay, which has worked fine for over fifty years. It is an input to the engine computer too.
When I worked at a very nice family-owned Chrysler dealership, I had a no-crank condition caused by a defective engine computer. If that is what is causing your problem, you can bypass the starter relay to crank the engine, and it will run fine. I do not remember which type relays you have. My drawings for relay terminals are on a different computer that crashed yet again, so I cannot post it right now. Instead, another way to bypass it is to remove it, pop its cover off, reinstall it that way, then squeeze the contact. The engine will start if the ignition switch is on.
Jul 18, 2016 at 11:02 PM
