ignition
2008 FORD
90 MILES • 4 CYL • FWD • AUTOMATIC
EMMETT WILLIAMS
Car cut off while driving and will not cut back on
Mar 25, 2017 at 7:05 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge it may have gone out and also scan for codes auto parts does for free and rent the gauge it can be either of these causing it.
Mar 25, 2017 at 9:56 AM
EMMETT WILLIAMS
Hum says crank/ cam sensor range/ performance
Mar 25, 2017 at 10:02 AM
HMAC300
  • 48,601 POSTS
could be that as well if that is what a scanner reads what is code?
Mar 25, 2017 at 10:15 AM
EMMETT WILLIAMS
P1336
Mar 25, 2017 at 10:18 AM
HMAC300
  • 48,601 POSTS
see pic for causes I took this code off of a focus because you did not send what model or engine size so there could be a tsb on this. It is says it is both crank or camshaft sensor are damaged but it could also be a broken jumped timing belt/chain causing it. you'll need a mechanic to look at it to determine the latter part.
Mar 25, 2017 at 12:28 PM
