Ignition, key without chip will not start the vehicle
2007 SUZUKI SWIFT
150 MILES • 1.5L • 4 CYL • 2WD • MANUAL
BILLY THERON
  • 7 POSTS
Greetings. key without a chip and it cannot start the car (orange immobilizer symbol on dashboard ).
Will replacing second hands) Ecu+ignition cylinder+keys solve the problem ?
Thanks in advance.
Nov 11, 2020 at 11:02 AM
We need to check for codes because most likely you have a code in the BCM that will tell us what the issue could be.
Take a look at this diag chart for this warning light and it basically tells us what the issue could be. Thanks
Nov 11, 2020 at 11:46 AM
BILLY THERON
  • 7 POSTS
Here is the short video i took. The immobilizer is flashing.
Nov 11, 2020 at 12:20 PM
Just to be clear, you are trying to start the vehicle with a key that doesn't have the chip in it? Or your vehicle does not have a key with a chip in it?
I think your vehicle has the chip key which means it will not start unless you have a key with a programmed chip in it. So if that is the case, we need to get a key programmed or this will not start.
Let me know if this is the case. Thanks
Nov 11, 2020 at 1:58 PM
BILLY THERON
  • 7 POSTS
Yeah, you're right. The key break and the chip got lost.
Nov 12, 2020 at 8:23 PM
Okay. Unfortunately that is the issue. You are going to have to get a key with the chip and have it programmed in order to get this started again.
Nov 13, 2020 at 3:35 PM
BILLY THERON
  • 7 POSTS
Thanks for your response sir.
Nov 13, 2020 at 8:09 PM
You are welcome. Please come back to 2CarPros and thanks for using us this time.
Nov 14, 2020 at 10:43 AM
BILLY THERON
  • 7 POSTS
Greetings, can i use second hand ignition cylinder with its keys?
Nov 17, 2020 at 1:17 AM
Not to solve your issue. You could use them but you have to have them programmed to the other modules on the vehicle and I am not positive that they can be programmed to more then one vehicle. Meaning once they are programmed to one vehicle they can't be swapped to another.
If you think about it, if this was possible then all someone would have to do is swap out the switch to another with a set of keys and they can drive off with any of these vehicles. Unfortunately, I think the best option is to get a key and have it programmed.
Nov 17, 2020 at 5:25 PM
BILLY THERON
  • 7 POSTS
Thanks very much for your response sir.
Nov 17, 2020 at 8:08 PM
You are welcome. Thanks for using 2CarPros. Please come back in the future. Thanks
Nov 18, 2020 at 6:08 PM
BILLY THERON
  • 7 POSTS
Greetings, is is possible to lower the front end of a car and leaving stock shocks and springs at the back?
Nov 25, 2020 at 8:15 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Since a suspension question is not related to car keys what we ask you to do is start a new question. Here is the link:
Hope this helps and thanks again for using 2CarPros.
Nov 26, 2020 at 9:10 AM
