Ignition
2002 HONDA ODYSSEY
145,657 MILES • 3.5L • V6 • 2WD • AUTOMATIC
RIHARD RICHIE AWLARMELAYKON
My car ignition indicator on the dashboard has been blinking for months and sometimes when i want to turn on the ignition it gets stuck, but when i twist the key it works. yesterday i was driving then i packed the car when i wanted to start the car it got stuck and took about twenty to thirty minutes of trying before it starts. then my car only started one more after that. it has been about twenty four hours now that I have been trying, no luck. something the key beep sound when i insert it but it will not turn. what can i do?
Jun 11, 2017 at 1:28 PM
FREEMBA
  • 1,152 POSTS
Try a second ignition key to see if the results are the same.
If so, spray some electronic cleaning "fluid" into the ignition keyhole (or rub dielectric grease onto the key) and then try to start the vehicle. This works in a lot of cases.
If none of this works, drop by the dealer to see if they will give you the "brake-by-pass code" which will allow you to start the engine. If this code works the you can be sure that your problem is a faulty immobilizer unit.
Jun 11, 2017 at 3:53 PM
