defrost switch does not power on and the fuse is not blown
2009 NISSAN VERSA
110,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
NICHOLE SCOTT
I just had a new rear windshield replace, but my rear defrost was out long before it was smashed. I know my fuses are good. I am not sure about the relay, but I do know the switch inside my dash does not power on. How can I test the switch alone? Thanks.
Jan 10, 2018 at 12:27 PM
Here is a guide and the rear window defogger wiring diagram so you can see where you are losing power at. There is a relay as well that should be checked.Below are the fuse panel and relay locations so you can do some testing.
and
Check out the diagrams (below).
Jan 11, 2018 at 2:56 PM
