Idle air control valve?
2000 PONTIAC GRAND AM
293,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
2000 PONTIAC
  • 8 POSTS
I am having an idling issue with my 2000 grand am. I have replaced the idol air control value about 3 to 4 time with different senses but I still have a problem will the rpms sitting low yet when at sit at atop sign an it's warm runs fine on when in motion can someone help me fix my problem
Mar 31, 2026 at 3:51 AM
It the engine misfiring at idle? Please upload a short video in your response of the engine running at, so I can see what's going on for sure. I have seen the EGR valve leak, or just a good old fashion vacuum leak. Here is a video to help with the vacuum leak and testing the EGR valve.
https://www.youtube.com/watch?v=LRKWV4Are5c&pp=0gcJCdkKAYcqIYzv
and
https://www.youtube.com/watch?v=DqUCbbKdWf4
Pleas go over this guide as well
https://www.2carpros.com/articles/low-engine-idle
Please go over these guides and get back to us. Ken
Apr 1, 2026 at 9:23 AM
2000 PONTIAC
  • 8 POSTS
Thanks Ken for replying back to me. I have replaced vacuum lines and replaced all the sensors on my throttle body an I still have the same idol problem wish I can get it running right. I called a couple shops but they want to run i diagnostic test on it but can't afford it I been working on my own for for years. I have a picture for you hope you can still help me out with the problem. Thanks again
Apr 8, 2026 at 3:46 AM
I need a video of the engine idling, did you run the codes?
Apr 8, 2026 at 9:33 AM
2000 PONTIAC
  • 8 POSTS
This is the car running but it only does it when it's all warmed up the idol is low. I do have alot of blow by an when I take the oil cap off I have air coming out so I may think it could be rings an seal issue but don't know. I have tried everything replaced just about everything sense in the car fixed all the vacuum lines everything so don't know what it could be.
Apr 8, 2026 at 12:48 PM
When it is idling does the engine run smooth? Did you go over this guide?
Apr 9, 2026 at 6:22 AM
2000 PONTIAC
  • 8 POSTS
So my car will start up normal and run good for about 20 to 30 mins then the idol will drop an sound rough. I have all kinds of different codes pop up on my OBD reader but like I said I have replaced all the sence in the car an gaskets even the o2 sensors I have change I am curious i been reading that if you don't get the oem part for the car that it can have different voltage to them parts you but that would throw it off.
Apr 9, 2026 at 12:47 PM
Can you tell me what cods you are getting? It sounds like you may have a shorted coolant sensor or a bad PCM.
Apr 10, 2026 at 8:43 AM
2000 PONTIAC
  • 8 POSTS
The coolant sensor is new to so don't think it's that but it could be the PCM but I did disconnect it an put it back in the car to see if I can get the car to run right
Apr 11, 2026 at 12:15 PM
Yep it could be, did you get the chance to run the codes?
Apr 12, 2026 at 8:19 AM
2000 PONTIAC
  • 8 POSTS
The codes don't pop on like that it's just the cars idling issue when it's warmed up an still at idol the car runs real good on hwy an the last code that came up was a 02 sensor but they are new to. I did clean them with the right stuff looked it up so I am cleaning them right just don't get why the car is running like this it ran great with all the old parts plus I did replace the whole timming to on the car an retimed it myself
Apr 12, 2026 at 8:30 AM
Okay we should do compression test to make sure the engine is in good shape this video will show you how.
https://www.youtube.com/watch?v=KOxIm1F8AW0
Apr 12, 2026 at 8:47 AM
2000 PONTIAC
  • 8 POSTS
Well I did the compression test on all cylinders they all came out to the same psi all where past 150 so hope that is a good test now I need to figure out the real problem now it has to be some sensors I am thinking but hard to check them
Apr 13, 2026 at 5:53 PM
Lets try servicing the throttle body, this guide can help.
Good job on the compression test. Also, when driving the car does the engine have good power?
Apr 14, 2026 at 7:50 AM
2000 PONTIAC
  • 8 POSTS
Well I don't know how fast the gears are suppose to kick in at but it does take a bit for it to kick in all the gears. The car runs good on the hwy but think I do burn alot of gas just put new ac delco plugs in too. The only sensor I did not replace is the crankshaft sensor curious if that would be the problem but I think it's the o2 sensor cuz that is the P0141 code that has been coming up. I don't get anything about the actuator but I am looking into it but thanks for being a great help on my car.
Apr 14, 2026 at 2:43 PM
That is a good clue that the catalytic converter can be partially clogged up, does the engine have good power ? If not this will be the issue, here is a video to help check the cat.
https://www.youtube.com/watch?v=kNXh1Lphzr4
Apr 15, 2026 at 7:35 AM
2000 PONTIAC
  • 8 POSTS
Well I replaced the intake gasket with the studs are all new even the exhaust is replaced with new pipes so I still don't get why is it doing it but you could be right I did use some teckron to clean the engine after the oil change but still have that idol issue.
Apr 16, 2026 at 3:48 AM
Did you service the throttle body? Also, lets check for vacuum leaks.
Let us know what you find.
Apr 16, 2026 at 9:02 AM
