Idling stumbles like head gasket bad?
1993 MERCURY TRACER
141,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
KRISTINEDELANEY
When idling the engine stumbles as if the head gasket is bad. King says there's bubbles on the dip stick. I have not seen them. When traveling the engine does not stumble or miss but seems like it should have more power. We are opting to replace head gasket. It gets up to 70mph decently. I would not want to try to pass someone going 65 however without a mile and half to do so. I have not had the car long enough to know what normal is. Replaced the thermostat and changed the oil. Someone said it needs a head gasket. What say you? Thank you- Kristine Delaney
Apr 2, 2024 at 1:20 AM
Does the car overheat, or do you have milky looking oil? if not usually a head gasket will not make the engine stumble at freeway speeds. Here are guides to go over to help see what I am talking about:
To me it sounds like you need a fuel filter which if it is clogged the engine will not have power at higher speeds and stumble. Here is another guide to help:
https://www.2carpros.com/articles/engine-hesitates
Please go over these guides and get back to us.
Apr 2, 2024 at 8:37 AM
