Idling roughly when stopped?
2002 SUZUKI GRAND VITARA
150,000 MILES • 1.6L • 4WD • MANUAL
TIMANAJONES
  • 4 POSTS
I haven’t been driving my vehicle due to needing to change the clutch slave, after 5 months I’ve now had it replaced and now my car is idling roughly/shaking when vehicle is stopped. Fine when driving. When listening to my vehicle outside of it I can hear like fan noises ?
Never did this before it broke down due to the clutch slave.
Help.
Sep 13, 2024 at 2:52 AM
TIMANAJONES
  • 4 POSTS
This is what it sounds like by the way.
Sep 13, 2024 at 2:56 AM
They must have bumped or left a vacuum line off. Thanks for the video btw, it helps. Here is a guide to help you find out what the problem is:
https://www.2carpros.com/articles/repairing-engine-rough-idle-issues
Do you have a check engine light on? If so, let's get the codes, this guide will help with that as well:
Please go over these guides and get back to us.
Sep 13, 2024 at 10:16 AM
TIMANAJONES
  • 4 POSTS
No engine light on or any codes coming up.
Sep 13, 2024 at 8:11 PM
TIMANAJONES
  • 4 POSTS
This the boot to my clutch slave it’s torn, would this cause it?
Sep 13, 2024 at 8:34 PM
No, that would not cause the engine to run rough at idle. did you check for vacuum leaks? Also, when was the last tune up?
Sep 14, 2024 at 6:51 PM
