Are there any codes in the system? Is the check engine light on? You can have a parts store read the codes for you for free. Once you know the codes, let me know so I can help narrow the area of failure.
No engine light on no codes on. Yesterday when I first started the car it was fine I needed to lock the house so I turned it off when I came back about 2 minutes later and started the car again is when the idle problem started.
Jul 20, 2020 at 8:39 AM
CERTIFIED EXPERT
Okay, I would try cleaning the throttle body as I suggested to see if it is any better.
Jul 20, 2020 at 8:58 AM
LEANORE HAYES
MEMBER
Thank you. I will let you know if it works or not.
Jul 20, 2020 at 9:31 AM
LEANORE HAYES
MEMBER
I went out this morning and started the car and it is running great again, didn't have to do anything very mysterious.
Jul 21, 2020 at 2:21 PM
CERTIFIED EXPERT
I understand. The issue will return as nothing has been done for the issue.
