idles won't accelerate
1984 BMW 633 CSI
135,000 MILES • 3.2L • 6 CYL • RWD • MANUAL
FRHORNSBY
It starts and idles, but when you give it gas won't go above 1500 RPM. Things I've done, checked fuel pumps, both work, airflow meter also fine, relays fine, plugscap, rotar all fine, catalytic converter not plugged, crank shaft position sensor replaced,
Feb 22, 2016 at 9:38 AM
DOCHAGERTY
  • 9,603 POSTS
Timing? Fuel pressure? You said crank position sensor, which one? There are two and they interchange. What happened, when did this start. How do you know the cat isn't plugged?
Feb 24, 2016 at 8:54 AM
