Try this and let me know the results. Also, let me know if you have checked for engine vacuum leaks. Additionally, confirm there is nothing binding on the throttle cable preventing the throttle plate from fully closing. See pics below
Let me know what you find.
joe
See pics below.
Jun 2, 2023 at 8:18 PM
STEFFY831
MEMBER
Yes, did the trouble codes gave a code of 34 which was the IAC replaced that did not fix the problem. Have checked the cable that seems to be good no vacuum leaks. Also, there are times when the car is idle high that it seems to just drive on its own without anyone pushing on the gas.
Jun 2, 2023 at 9:51 PM
CERTIFIED EXPERT
Code 34 is related to the manifold absolute pressure sensor (MAP). That could be causing the issue.
I attached the diagnostics below for code 34. Take a look through them and let me know if you are comfortable performing them.
Also, I attached a pic showing the location of the MAP.
joe
See pics below.
Jun 2, 2023 at 10:19 PM
STEFFY831
MEMBER
Hi, I replaced the map sensor yesterday and still nothing has changed it's still idling high I am completely stumped as to the issue.
Jun 13, 2023 at 5:11 PM
CERTIFIED EXPERT
Is the same code still present? If it is, are you comfortable performing the diagnostics above?
Also, this only happens in park or neutral. When you place it on gear, does it idle down or does the load on the engine simply slow it down? If you have it in gear and take your foot off the brake, does the car go on its own?
Jun 13, 2023 at 7:51 PM
STEFFY831
MEMBER
Ran codes again and getting no trouble codes at all. When it's in park and neutral the idle is high and when it's in gear it seems like it's idle is normal but it's not and yes when I take foot of pedal the car does go on its own.
Jun 13, 2023 at 8:14 PM
CERTIFIED EXPERT
Okay, if you haven't already, check and confirm there are no engine vacuum leaks.
If there are no leaks, take a look at the directions for idle speed adjustment. Since you already replaced the IAC, follow the directions where it discusses relearning the IAC. It starts with the number 6 toward the end of the pics.
