Idles high, hesitates or stalls when attempting to accelerate
1995 CHEVROLET MONTE CARLO
186,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
KELB1911
Car cranks fine. Ran and drove perfect until about a month ago. Now it loses acceleration on inclines, and when it comes to a complete stop (ie stoplight/stop sign) when I press the gas pedal, it hesitates and stalls out.
I have cleaned the throttle body, replaced IAC, TPS, MAP sensor, coolant temperature sensor, and fuel filter. No change.
Any help or assistance with this issue will be greatly appreciated.
Jul 2, 2020 at 1:05 PM
I suspect you have an issue with the purge valve. If these get stuck open then it can cause this issue. Basically the engine runs to rich and it will do what you are seeing.
I would remove the purge valve and inspect it to see if it looks like it has some charcoal build up in it. If it does then I bet you have raw fuel in the charcoal canister which breakdown the charcoal and causes the valve to stick.
Let me know what you find and we can go from there. Thanks
Jul 2, 2020 at 7:05 PM
