Idles great no smoke?
2001 DODGE RAM
333,000 MILES • 5.9L • 6 CYL • TURBO • 4WD • MANUAL
ASHLEY WILLIS
Okay, so i have a 24 v Cummins. She idles beautifully but after about 4 minutes she starts to rev up violently almost I feel like. Almost like she is bucking.
Oct 14, 2024 at 10:18 AM
The #1 issue with diesel engine is the fuel filter and water separator. Here is how to change it out and I have included how to bleed the air out of the system as well, also, do you have check engine light on? If so, we should run the codes to see which ones are stored, this guide can help:
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 14, 2024 at 11:39 AM
ASHLEY WILLIS
There is no check engine light on. But it is throwing 2 codes.
Oct 14, 2024 at 3:50 PM
ASHLEY WILLIS
Our truck is a 4wd.
Oct 14, 2024 at 4:00 PM
Okay, what codes are they? Also, did you try replacing the fuel filter and drain the water out?
Oct 15, 2024 at 9:16 AM
