Just spent the last few months very carefully taking my car listed above apart to do the front and rear main seals that went out last November and the car has sat. While I had it apart I deep cleaned the abundance of grime out of the intake. I replaced all mounts, EGR valve, VTEC solenoid, exhaust manifold to sport header, both top and bottom o2 sensors, stock exhaust to a sport, replaced the catalytic converter, throttle body and all connected sensors on it, and of course front rear seals oil and coolant new! I didn't do the plugs, wires, cap or button due to they were done not long before I started the tear down. After checking everything numerous times i started it, and it idles. I barely touch the gas pedal and it shuts off. Bad gas? Should I do the plugs and wires? Any advice would be greatly appreciated!
Sep 9, 2021 at 12:25 PM
