Idler arm
1999 BUICK PARK AVENUE
168,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
STEVE CROISSANT
The idler arm (tension pulley) bounces up and down when the engine is running. I replaced the tension assembly but it is still bouncing. After taking off the serpentine belt it seems like the power steering pulley is not spinning as free as it should. Do I need to replace the whole power steering pump and pulley or just the pulley? The power steering works fine. Thank you for any advice.
Jun 2, 2016 at 8:28 AM
HMAC300
  • 48,601 POSTS
it is normal for tensioner to bounce up and down because it keeps belt tight at different rpm's. If the power steering works fine I would leave it alone.
Jun 2, 2016 at 9:28 AM
