Where is the Idler air control valve located?
2009 SUZUKI ALTO
180,000 MILES • 1.0L • 3 CYL • 2WD • AUTOMATIC
TAINA
  • 12 POSTS
Location of idler air control valve with pictures.
Oct 22, 2024 at 9:28 AM
This car does not have an idle air control motor. The idle speed is controlled by the throttle body, what problem are you having? Stalling at idle? This guide can help:
https://www.2carpros.com/articles/stall-at-idle
Oct 23, 2024 at 11:13 AM
TAINA
  • 12 POSTS
Has low idle not running rough, just low idle.
Oct 23, 2024 at 5:41 PM
TAINA
  • 12 POSTS
Was wondering if idle can be adjusted.
Oct 23, 2024 at 5:42 PM
It cannot be adjusted; the computer sets the idle speed. I would service the throttle bore and check for vacuum leaks. This guide will help, and I have included instructions for your car in the images below:
Use this guide when the engine is cold only:
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Oct 24, 2024 at 9:26 AM
