Did this happen all at once? Does the check engine light stay on when the engine is running?
This vehicle has a throttle cable that may need to be adjusted or is damaged from age and not allowing the throttle to fully close.
I attached the directions below for adjustment. Try this. Also, inspect the cable both at the throttle body under the hood and in the vehicle at the throttle pedal for indications of fraying or anything that may cause it to stick.
If you question anything, disconnect the cable at the throttle body to make sure it is fully returning to the closed position. I attached a few additional pics so you can see the cable, where it is routed, and how it is connected at the TB.
See pic below.
May 28, 2022 at 11:28 PM
