Idle surge and engine cuts out
1995 NISSAN TRUCK
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
PETELG18
  • 4 POSTS
When driving the engine will cut out for just a split second.. Usually never shuts off and at times the rpm will surge at idling. For example: If I slow down or come to a stop there may be an idle surging (almost shuts off) and then at the next stop or stop light everything runs smoothly. Thanks for any advice. Pete
Oct 25, 2017 at 12:17 PM
KHLOW2008
  • 41,814 POSTS
Hi Pete,
Is the malfunction indicator light (check engine light) indicating? Have you had the vehicle checked for trouble codes? I would suggest starting with this. A scan would help in diagnosing the cause of the problem.
There are a few possibilities for such problems and one of it is a bad MAF. It can also be due to a faulty or dirty throttle body or the auxiliary air control valve.
Oct 26, 2017 at 8:29 AM
PETELG18
  • 4 POSTS
Hey my friend. Thank you for the reply. This problem has been going on for awhile. At one time the "service engine" did come on but went off. While the problem continues the "service engine light has not come back on. After the engine light came on and went back off. I changed the oil and bought a new battery. Did disconnecting the battery erase the codes? Thank you again for helping me.. Pete
Oct 26, 2017 at 11:11 AM
KHLOW2008
  • 41,814 POSTS
Disconnecting the battery would erase the memory (fault code) of the ECM and if problem does not recur, it would not show again. However, there are some fault codes that do not trigger MIL but would be recorded by the ECM.
Getting a scan done is still a good idea.
Try cleaning the AAC and throttle body to see if it makes any difference. By the way before you start with anything, ensure there are no breaks in the intake hose from the air cleaner to the throttle housing. Any air leak can cause havoc with the idling system.
Oct 26, 2017 at 7:09 PM
PETELG18
  • 4 POSTS
Thank you a bunch buddy. I will start checking.
Oct 27, 2017 at 7:24 AM
KHLOW2008
  • 41,814 POSTS
You are welcome.
Let us know how it goes and if you require further information or assistance, we are here for you.
Have a great weekend.
K H Low
Oct 27, 2017 at 1:54 PM
