Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Contour
Engine
Symptoms
Idle Erratic
idle problems
1999 FORD CONTOUR
125,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
BLACKJACK1960
MEMBER
1 POST
FOLLOW
my car at idle in park, after you start it up it races high rpm and then drops to low rpm. it cycles up and down. IAC valve problem?
Aug 3, 2017 at 5:29 AM
CERTIFIED EXPERT
It sounds more like a vacuum leak or MAF is out of range. Here are some guides to help you run some simple tests.
and
https://www.2carpros.com/articles/replace-an-air-intake-boot
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
and
Please run some tests and get back to us we are interested to see what it is.
Aug 3, 2017 at 3:27 PM
