More then likely this is a vacuum leak. What is happening there is air coming in which the PCM is trying to match the fuel to it and the RPM raises, then it drops and raises again.
Use this guide to figure out where it is:
On most vehicles there is a learn procedure that needs to be done after the replacement of this but I don't see one on your vehicle. Which means you should not need to perform this but if you find no leak you can try and perform an ECM reset which will force the ECM to relearn the throttle an all other monitors. It is no different then shutting off your phone and rebooting it when it locks up.
See below for this detail. Let me know what you find. Thanks
Mar 20, 2021 at 8:40 AM
