After I replaced my head gasket, the car had an issue idling. The idle hunts and stays at around 1,500 RPM's when it is usually around 500. I replaced the throttle body with one from the junkyard and it fixed it for a couple of days but now it's the same problem. I've replaced the MAP sensor, throttle position sensor, and I've gone through 3 IAC valves. I'm at a loss and don't know what to do. No vacuum leaks either. I've plugged all the ports to test.
Nov 18, 2020 at 2:14 PM
