I working on the pickup listed above XE model. it has very low miles it was only driven once a week for 20 years so that's why it has low miles and is in very good condition. a couple weeks ago the car was started and the idle kept trying to drop, it kept bouncing down from 1,000 to 300 RPM's. it never shut off but when it dropped low it shook so hard that it felt like it was shutting off almost like a lawnmower and it wasn't surging it wasn't going up and down it's just when it gets to temperature and it tries to lower to the RPM's that it should idle at it keeps dropping like it's shutting off almost like somebody's turning it off and back on real quick. I have cleaned the EGR valve and throttle body, it has a new air filter and spark plugs. I've also replaced the mass air flow sensor to idle air control valve and the throttle position sensor. I took it to a mechanic and they replaced the distributor rotor and cap and set the timing chain. he also claimed that he adjusted the idle. the car is not only doing the same thing but it's doing it worse now it is actually surging and it's doing it harder it's trying to shut off and it's bouncing up and down. He said he cannot figure out the problem and I've replaced all the common issues so I'm not quite sure where to go from here.
Jun 20, 2020 at 12:36 PM
