idle is low and rough in gear
1994 DODGE INTREPID
71,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
ALSODER
  • 8 POSTS
Replaced spark plugs, I think wires look to have been replaced once if they were original would they have the Chrysler emblem on them? New air cleaner and pvc valve. Cleaned air idle control valve. Car runs great under throttle power. Idle in park seems to be ok, put when you put it in gear it is low and rough. Thanks Alan
Sep 8, 2015 at 7:26 PM
They should indicate the chrysler emblem. As far as the idle, are you sure there are no vacuum leaks on the engine? Have you checked the idle air control valve (IAC)? The IAC is responsible for maintaining the engine idle speed.
Sep 8, 2015 at 7:39 PM
ALSODER
  • 8 POSTS
I don't see any vacuum leaks. I took out the Iac and cleaned it with carb cleaner. How do I now if it is working right? Is there a way to test it?
Sep 8, 2015 at 7:58 PM
Remember, chances are you won't see a vacuum leak. Often times (VERY CAREFULLY) people will use carb cleaner and spray it on the vacuum hoses. If there is a leak, the RPM's will increase. Also, you can check vacuum by using a vacuum gauge to determine if it is low. As far as the IAC, I would suggest removing it and having someone cycle the key from off to on to see if the pintel is moving. If it isn't, check to see if there is power to the harness.
Sep 9, 2015 at 6:08 PM
ALSODER
  • 8 POSTS
Hi, I have checked everything you have mentioned it all looks ok. I am going to see if I can get a code out of it. A new problem just started the power steering is buzzing and the fluid is getting scorching hot. It this the power steering pump.? Thanks Alan
Sep 17, 2015 at 1:11 PM
Check to see if there is a code. As far as the PS fluid, it will get hot. That is normal. I.m not sure why it is making noise. Are you sure the belt is tight?
Sep 20, 2015 at 6:07 PM
