Idle increases when you shift into Drive or Reverse
2000 TOYOTA COROLLA
190,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
MEGACAB78
Just put a new head on. initial test drives went fine. After sitting for a while, car starts fine and idles normal. then shift into reverse the rpm jumps up about 500 rpm or so. shift to neutral and the car returns to normal idle. shift into drive and the rpm increases again. problem was there for the entire 30 mile drive.
Any idea's??
Sep 24, 2015 at 9:35 AM
Check for vacuum leaks and check the idle air control circuit.
Sep 24, 2015 at 5:56 PM
