Idle drops and comes back when first started
1988 TOYOTA PICKUP
304,000 MILES • 3.0L • V6 • 4WD • MANUAL
AMENDELSON
Engine has head gasket leak on cylinder six. Plug no longer fires and last time I pulled it the head threads came out with it. That said, when the engine is cold the idle drops and comes back, drops and comes back. When hot it holds an idle just fine. Truck still has lots of power even with a bad cylinder. I need to change the head but before that, any suggestions on the idle problem?
Aug 13, 2017 at 7:14 AM
The engine will never run right with a bad cylinder and a blown head gasket. Replace the gasket and the engine should run okay once again.
Best, Ken
Aug 14, 2017 at 7:18 PM
STEVE W.
  • 15,113 POSTS
The varied idle can be due to the bad gasket. It would likely leaking between cylinders and the engine then stops firing on two cylinders until it heats up and the head expands and the leak slows enough that the other cylinder comes back. It essentially loses the power from those two cylinders, slows down and then speeds up as the rest fire.
I would get it changed now, as the leak could easily cause it to hydro-lock and bend a rod/snap the crankshaft. Plus the unburnt fuel is probably washing the cylinder and you may end up replacing the engine, not just the head gasket.
Aug 14, 2017 at 9:53 PM
