I'm hoping someone can help. has a chatter. At idle only, if you accelerate it stops. It only does it when the motor is warm and at operating temperature. The sound is worse when you turn the wheels lock to lock. If the ac is off, it rarely makes it, but when the ac is on, it is loud. It sounds loudest at cylinders 4 and 6 and only on the top of the motor. It sounded originally as if it was coming from the power steering pump. I replaced it but it didn't help. The sound started after I replaced the upper and lower oil pan gaskets. Everything looked good when I changed them. I have also replaced all of the engine and transmission mounts. I have also replaced the tensioner, idler pulley, and belt. Thinking possibly a lifter. It runs smooth, no loss of power, no other issues. Has been going on for about 2 months now. Any ideas?
Aug 9, 2020 at 6:24 PM
