Idle air control valve noise
2001 KIA SEPHIA
81,000 MILES • 4 CYL • 2WD • MANUAL
SBAKER821
Over the course of I'd say four months there have been three times that I go outside hours after the car has been driven and I hear a winding or buzzing noise. Each time I grab the keys and start it and shut it back off and the noise is gone. Tonight was the third time and before I started the car I took a look under the hood and was able to locate the noise coming from the Idle Air Control valve. So I guessing I am just wondering if this is just a weird hiccup or if there is a known cause and solution. Thank you for any help.
Dec 16, 2020 at 5:33 PM
That isn't a common issue. It sounds like it is sticking and trying to find the off position. Since it is making noise, I would remove and inspect it. There is a chance carbon or dirt of some kind is causing this.
https://www.2carpros.com/articles/idle-air-control-valve-service
Try what the link indicates doing and let me know if it helps.
I will watch for your reply.
Dec 16, 2020 at 9:32 PM
