The throttle body has two different connectors one form TP sensor and IAC valve
The harness came with the engine but the harness has one connector that is an 8 pin for the electronic throttle body and mine has the IAC (4 pin) and the TP sensor (3 pins)....engine is always stalling because I need to keep the foot on the gas pedal. not unless either i adjust the throttle valve to keep open just enough for my engine not to stall or fix my IAC valve connect problem. how do I solve this?!
May 1, 2020 at 8:29 PM
