idle
2003 HONDA ODYSSEY
155,000 MILES • 6 CYL • FWD • AUTOMATIC
ADLERC
  • 5 POSTS
idle is fluctuating periodically between 1200 down to 200. the IAC sensor was replaced but problem still persists
Jan 28, 2016 at 8:15 PM
JOHNNYT73
  • 924 POSTS
Check the coolant level, and that all the air was bled out of the system.
Jan 28, 2016 at 8:25 PM
ADLERC
  • 5 POSTS
Thank you
How do I bleed the system on this model?
Jan 28, 2016 at 8:45 PM
JOHNNYT73
  • 924 POSTS
Just take off the radiator cap, fill with coolant, start the engine with heat on and let it idle till it reaches operating temp, raise the rpm to about 2500 and hold it for about 3 seconds each time, continue to check coolant level to the radiator fans come, when they do just put the cap on and your done.
Jan 29, 2016 at 4:55 AM
ADLERC
  • 5 POSTS
When I mentioned this to my mechanic he said that if I'm not overheating then the cooling system is fine and not at all connected to the issue of idle. What do you say about this?
Feb 1, 2016 at 12:38 PM
MHPAUTOS
  • 31,937 POSTS
may be an air lock in the throttle plate coolant passage, this would not cause any over heat issues, also clean throttle plate and clean IAC by pass air passage and make sure the IAC is actually working, take nothing for granted as new parts can be faulty.
Feb 3, 2016 at 11:33 PM
ADLERC
  • 5 POSTS
Actually, as I drove around a few days the idle settled into an almost perfect setting. Meaning, mostly it is stable at 5-600 rpm. Once in a while it will slightly fluctuate between 500 and 1100 rpm for a short period of time. Also, the computer is no longer indicating a faulty IAC. Should I just leave it at this point?
Feb 4, 2016 at 8:49 AM
MHPAUTOS
  • 31,937 POSTS
i would just drive and monitor the situation and re post if it is a ongoing concern.
Feb 4, 2016 at 12:34 PM
ADLERC
  • 5 POSTS
Thanks
Feb 4, 2016 at 4:34 PM
Did this problem resolve?
Apr 23, 2016 at 8:49 AM
