oil on all the spark plugs
2012 FORD FUSION
70,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
ITISME201411
  • 33 POSTS
I have the SEL model. I went and did a little tune up on it. It sounds pretty bad. Well when I went to go change the spark plugs I noticed a little bit of oil on all the spark plugs. Valve cover gasket? Or what would you suggest I check out first? Thanks.
Aug 10, 2017 at 1:02 AM
MHPAUTOS
  • 31,937 POSTS
This will be a rocker cover gasket.replace the gasket and you should be fine.
Aug 10, 2017 at 5:14 AM
ITISME201411
  • 33 POSTS
Is t that not the same as a valve cover gasket? And for a vehicle with 70,000 miles would this be a common issue? Or could there be something more extensive? Thanks.
Aug 10, 2017 at 10:16 AM
MHPAUTOS
  • 31,937 POSTS
Yes same thing fairly common as the plug tube seal is part of the rocket cover gasket
Aug 11, 2017 at 12:22 AM
ITISME201411
  • 33 POSTS
So that damn sensor that is by the number 2 cylinder.I cannot get that clip off it for the life of me.An I feel like an idiot.could I snip it an wire a new one in or would I have to buy a that whole wire harness?
Aug 12, 2017 at 8:57 PM
MHPAUTOS
  • 31,937 POSTS
Keep at it, don't cut the wire as this will cause a high resistance no Mayer how well you join it, the plug will have s lock tab, it may be inside the lug and a small probe may be required. It should in clip I know they can be a mongrel some times but it will let go
Aug 12, 2017 at 11:41 PM
