Identify part?
1983 TOYOTA PICKUP
239,000 MILES • MANUAL
SMITHEE
  • 8 POSTS
I’m having heck of a time figuring out what this part is I know it has a green connector and also connects to battery terminal, and it’s supposed to have 2 wires coming out of the green connector.
Apr 19, 2025 at 8:10 PM
I would just bypass the connector and wire it directly, where did you remove it from the alternator? Just make new wiring for it. Let me know if you need more help.
Apr 20, 2025 at 12:27 PM
SMITHEE
  • 8 POSTS
It disconnected from that plug but the wire that got burnt off is the issue because there is no power when it is connected.
Apr 20, 2025 at 6:33 PM
Okay, I assume the battery is stalled when you are testing? Did the I-let side of the connector go to the battery? If so, just wire the power wires together and don't worry about the connector. Thanks for the image.
Apr 21, 2025 at 9:56 AM
SMITHEE
  • 8 POSTS
What do you mean by that?
Apr 21, 2025 at 2:11 PM
You can add new wires and bypass the connector it is not needed.
Apr 22, 2025 at 10:37 AM
SMITHEE
  • 8 POSTS
Okay, but do you know what the part is even called? Because that’s what my question was anyways.
Apr 22, 2025 at 3:44 PM
It is called a "main power connector".
Apr 23, 2025 at 9:17 AM
