I live in regina, SK, all the service advisor told me , after he check for , the codes, that the intercooler has ice buildup on it, and to replace it, he wrote down both code s for me, when i got home ,i check out what those code mean., both of them were showing ,number 2 oxygen sensor is bad, i never had that problem before with my car, most of the driving i do is city driving, the day before the car started acting up ,i was out on the ring road, i maybe put 8 miles on the car, going from one dealer ship to the next one. It was not very cold that day, minus 15 Celsius. The car was running fine, my car is park outside all day, 2 days later when i went out to use it, the check engine light came on, right when i started it. It is solid, not flashing. In the city the car was running good, but i wanted to see if it would act up at highway speed. So once i got out on the highway, i went maybe about a mile, the car was running fine, all at once the power drop right down, it would go about 80 clicks only, i could tell it wasn't shifting properly ,after about 5 minutes , when it started losing power, the dash monitor was showing ,engine power is reduce, as soon as i could turn off from the direction i was going, to go back into the city, i drove about a mile and a half, then it started running like it should, when i got back into the city i went to put more gas in it, I filled it right up, then went to a restaurant ,i was in there only for a half a hour, come back out, i wanted to take it out on the highway again , to see if it would keep running normally ,in the city it was alright, the minute i get out on the highway again, it lost power , and the dash monitor was showing the same message again, the questions i have, is will they trough a code if there is a problem with the inter cooler, and also the turbo, or the transmission. I have been told it is a common problem with the Chevy Cruze intercoolers, icing up, i had it check again if any other codes have come up. Only the 2 from before showed up.
Jan 17, 2024 at 7:39 PM
