When I put the A/C on the car engine shake little bit, different idle sound, from the Hyundai agency they mention the IAC valve need immediate attention that is to replace the valve. Since there was no stock of the spare the owner couldn't replace it. As I friend I remove the IAC valve for cleaning.
Put new gasket, there was some carbon deposit. The car run smooth for few days and again it came back the engine shake.
I put the scanner there was no fault code found nor pending..
Question is, can a IAC valve become bad without any fault code present? Should i remove the throttle body and clean as well?How to confirm the IAC valve itself which is faulty?
Jan 13, 2021 at 5:28 AM
