I thought that because my shifter wasn't goin in gear that the problem would be either my clutch or slave cylinder.
1989 TOYOTA PICKUP
132,222 MILES • 4 CYL • 4WD • MANUAL
KNL 1963
  • 5 POSTS
When I would shift between gears,it would be like you have to push it into gear.And but now it wouldn't go into 5th & reverse.Could it be not enough gear oil,or the master cylinder or maybe a linkage in the transmission?
Jan 10, 2016 at 1:24 PM
yes, it could be a bad slave from too much free play, could also be a failed clutch as well.
ROy
Jan 10, 2016 at 1:48 PM
KNL 1963
  • 5 POSTS
I changed my clutch,throwout bearing
And slave cylinder.And then I bled the
master cylinder,but the pressure on the pedal wasn't all that firm.And of
Course I go to check the shifter it would go in gears1thru4 but 5& reverse wouldn't..
Thanks a lot
KNL
Jan 10, 2016 at 2:11 PM
how much free play do you have???
Jan 10, 2016 at 2:32 PM
KNL 1963
  • 5 POSTS
About an 1-1 1/2 in. Play..
Jan 10, 2016 at 3:12 PM
if you have a new clutch, slave cylinder and free play correct and bled, the only thing left is the clutch master cylinder
Jan 10, 2016 at 3:14 PM
KNL 1963
  • 5 POSTS
O k,I'll try and work on that..
Thanks a lot.
KNL
Jan 10, 2016 at 3:19 PM
KNL 1963
  • 5 POSTS
Hey,you know what I just started the truck to see if it would go in gear.So I
pressed in the clutch and tryed it out,
this time none of the gears work..What do you think is happening?
Thanks a lot
KNL
Jan 10, 2016 at 3:38 PM
the slave may not be moving from the bad master
Jan 10, 2016 at 3:42 PM
