Will not start after spraying carburetor clean in the new injectors
1987 MERCEDES BENZ 190E
85,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ADEL HAMMAD
I have the car listed above (W201). I was attempting to replace my fuel injectors because it was not running very smooth (vibrations when throttle is pressed when car is cold). I removed the old injectors and sprayed some carburetor cleaner spray in the holes where you place the injectors in an attempt to clean it. This has unfortunately backfired I guess. I placed the new injectors with new seals and put everything back in but the car would crank but not start. I thought the new injectors might be faulty so I placed the old ones again but still the car would crank but not start. Have I done a fatal mistake by spraying the carburetor cleaner spray in the holes where the injectors are placed? Is this a case of flooding? I left the car to sit for hours then tried again but to no avail. I have recently replaced the spark plugs and fuel pump and fuel pump relay are working fine. Please help
Nov 15, 2017 at 8:00 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That should not have hurt anything. I do not see a 2.0l engine. Is this perhaps a 2.3l engine?
Will the engine start up and run for a few seconds after spraying a couple of shots of starting fluid into the throttle body?
Nov 15, 2017 at 9:19 AM
STEVE W.
  • 15,113 POSTS
2.0 is a Euro engine option.
Carburetor cleaner should not have hurt it but it will not help it fire. Put the injectors back in, remove the plugs and crank it over a bit to blow out the cylinders. Use a torch or similar to burn the extra fuel off the plugs and dry them. Reinstall and try starting it.
Nov 15, 2017 at 10:36 AM
