I need to replace the hose goes from the throttle body to the water reservoir
2009 CHEVROLET AVEO
86,000 MILES • 2WD • AUTOMATIC
BREANNA CHRISTINA
The hose goes from the throttle body to the water reservoir and i don't know what it's called to look up the part. The connector on the end of the hose broke off now i'm guessing i need to replace the whole hose because it loose torn as well. Please help!
May 12, 2021 at 3:12 PM
Good afternoon,
The video did not show much as you moved the phone around and we could not see anything.
I attached a picture of the throttle body. Is the hose I circled the hose you need? It is called a throttle body coolant hose from the throttle body to the surge tank.
May 12, 2021 at 3:32 PM
BREANNA CHRISTINA
Hi Roy,
Thanks for your quick response. No actually the hose is attached from the part of the throttle body i circled to the water reservoir.
May 12, 2021 at 3:39 PM
Okay, great. That is still the same hose since you have 2 at the throttle body.
This is not a hose a parts store will have. You will need to go to a Chevrolet dealership parts department for the hose.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
May 12, 2021 at 4:12 PM
