After replacing head gaskets the timing chain came off
2005 DODGE RAM
170,000 MILES • 4.7L • V8 • 4WD • MANUAL
ROYCHILDS
How can I make sure it was put back on properly before I put the engine back together?
Sep 3, 2018 at 9:21 PM
Good morning.
My first question is, why did it fall off? Did you find the reason for this failure? Timing chains do not fall off.
You will need to be sure the marks are aligned properly for proper valve timing.
The crank mark is below and the cam marks are attached as well.
Sep 4, 2018 at 3:24 AM
