I put in a new fuel injector and new connector and replaced wire from connector to PCM then replaced the PCM with PCM from wrecker from same year
and model. I started car it ran for about sixty seconds then stopped. When I turned the key to the on position all the dash lights came on and slowly when out but the security light come back on which would not let the starter turn. Then I put the old PCM back in and the car started and would not idle smooth. Same p0204. Can I disable the security system myself?
Oct 22, 2018 at 11:37 PM
