I recently installed a new starter now no crank no start
1992 LEXUS LS 400
190,000 MILES
TIMMAHANEY
  • 65 POSTS
I have done everything i can think of, when i turn the radio on it goes in and out like there is a short, or when I roll up the window the locks unlock. My alarm system light was not working i got the light to flash. I am hoping that someone can help me with this problem. please let me know what to do. Sincerely, Tim Newton
Feb 15, 2018 at 11:22 PM
Good morning.
Have you checked the battery for proper voltage? It sounds like you have low voltage.
Why did you replace the starter?
Feb 16, 2018 at 4:09 AM
TIMMAHANEY
  • 65 POSTS
Because like i would say about four days prior to me changing it it would start to like drag it was getting harder and harder to start. So my brother said it was the starter. And so I put in new valve covers gaskets and I put in manifold gaskets to. But when I first put it in the engine tried to start when I put the battery cables on. The key was not even on. I would really like some help i really love this car and I plan to have it completely restored some day.
Feb 16, 2018 at 4:24 AM
Okay, did you verify the wiring to the starter? Make sure the positive cable from the battery is not touching the small terminal on the solenoid. that will activate the starter.
Also, check the battery voltage and make sure is it at 12.6 volts. low voltage can make a lot of strange things happen.
Feb 16, 2018 at 6:06 AM
TIMMAHANEY
  • 65 POSTS
Okay thanks. I will do that. is there anyway I can test that without having to tear it all down again?
Feb 16, 2018 at 6:13 AM
Check the wiring that goes to it. I believe the wires come in from the back of the block. make sure there is not damage to the little wire to the solenoid.
Feb 16, 2018 at 6:14 AM
TIMMAHANEY
  • 65 POSTS
Well I cannot see if there is from the bottom I think I might have to tear it down.
Feb 16, 2018 at 2:09 PM
Sorry to say but I agree.
Feb 16, 2018 at 2:50 PM
TIMMAHANEY
  • 65 POSTS
Now when I put my light to the starter relay box it lit up, so that tells me that the box is good correct? Once i take it apart i will send you a picture.
Feb 16, 2018 at 3:04 PM
what terminal on the relay?
Feb 16, 2018 at 3:18 PM
TIMMAHANEY
  • 65 POSTS
The starter relay, I had somewhat of a breakthrough tonight. i fully charged my battery put it in my car and got in and tried to start it and it turned over as I was turning the key before I even got to the on position. Now that is where I am at.
Feb 17, 2018 at 1:12 AM
Okay, assuming it did not do that prior to the repair. you will need to go to the starter, sorry to say, and check the wiring. the positive cable may be touching the little terminal or the little wire to the solenoid may be the issue. if all them are okay, then you may have either a bad new starter or an ignition switch, which I doubt since this was not an issue before.
Feb 17, 2018 at 6:03 AM
TIMMAHANEY
  • 65 POSTS
I will check and let you know.
Feb 17, 2018 at 12:40 PM
Okay, we will be here to help.
Feb 17, 2018 at 1:32 PM
