I needed a computer wiring diagram
2007 HYUNDAI SONATA
2,007 MILES • 4 CYL • 2WD • AUTOMATIC
ALAZRI
  • 19 POSTS
I need a scheme.
May 29, 2021 at 2:05 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
There are numerous different wiring systems on a vehicle. Which one do you need? Get back to us with which circuit you need and we'll be happy to provide. Thanks for using 2CarPros.
May 30, 2021 at 2:17 PM
ALAZRI
  • 19 POSTS
I need a cruise control wiring diagram.
Jun 1, 2021 at 10:06 AM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the information you requested. This is a tutorial for you to view on how to test electrical wiring:
I've attached below the cruise control wiring diagram for your vehicle. I've cut the pictures into 3 pieces so you can view larger. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 2, 2021 at 4:52 AM
ALAZRI
  • 19 POSTS
And I need computer data lines wiring diagram.
Jun 2, 2021 at 6:35 AM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the computer data line wiring diagram you requested. I've cut the picture into 3 pieces so you can view larger. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 2, 2021 at 7:11 AM
ALAZRI
  • 19 POSTS
I need speedometer wiring diagram.
Jun 3, 2021 at 11:49 AM
ALAZRI
  • 19 POSTS
I need Instrument Cluster Wiring Diagram.
Jun 3, 2021 at 2:07 PM
DANNY L
  • 5,648 POSTS
Hello again.
I've attached the instrument-cluster panel wiring diagram below which also includes the speedometer. I've cut the pictures again into 3 pieces so you can view larger. Hope this helps and thanks again for using 2CarPros.
Jun 3, 2021 at 2:30 PM
ALAZRI
  • 19 POSTS
I need computer wiring diagram.
Jun 4, 2021 at 7:24 AM
DANNY L
  • 5,648 POSTS
Hello again.
Do you mean the ECM or PCM- Engine control module, Powertrain control module? Thanks again for using 2CarPros.
Danny-
Jun 4, 2021 at 7:21 PM
ALAZRI
  • 19 POSTS
Both, I need PCM and ECM wiring diagram.
Jun 4, 2021 at 9:57 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the diagrams you requested. I've attached below the ecm pin out below. I've also attached the wiring diagram and cut into 3 pieces so you can view larger. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 5, 2021 at 7:04 AM
ALAZRI
  • 19 POSTS
I need fuse wiring diagram.
Jun 5, 2021 at 10:00 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the fuse diagram you requested. I've attached the pictures below for your Hyundai. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 6, 2021 at 6:18 AM
ALAZRI
  • 19 POSTS
Thanks for everything.
Jun 6, 2021 at 8:08 AM
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks again for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
Jun 6, 2021 at 10:54 AM
ALAZRI
  • 19 POSTS
I need clock spring wiring diagram.
Jun 7, 2021 at 11:13 AM
ALAZRI
  • 19 POSTS
Where can I find the joint connector M81?
Jun 7, 2021 at 11:57 AM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the clock spring diagram you requested. I've cut it into 3 pieces so you can view larger. I've also attached a picture of M81 joint connector which is located behind right side of dash. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 7, 2021 at 4:07 PM
ALAZRI
  • 19 POSTS
A solution that needs to be programmed after installing the installer and its wires to light a bulb on the panel.
Jun 9, 2021 at 1:37 PM
ALAZRI
  • 19 POSTS
A solution that needs to be programmed after installing the set / cruise and its wires to light a bulb on the panel.
Jun 9, 2021 at 9:14 PM
DANNY L
  • 5,648 POSTS
Hello again.
Unsure of this question. You will need to clarify. Thanks again for using 2CarPros.
Danny-
Jun 11, 2021 at 9:47 AM
ALAZRI
  • 19 POSTS
The cruise control wires in my car are not connected inside the car. do I need to program the car to work? Where I connected it according to the scheme.
Jun 12, 2021 at 11:52 AM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the wiring diagram for the cruise control system. The wires will need to be attached to the multi-function switch which is located on the steering column. I've cut the pictures into 3 pieces each so you can view larger and attached them below. Hope this helps and thanks again for using 2CarPros.
Danny-
Jun 12, 2021 at 12:27 PM
ALAZRI
  • 19 POSTS
Can you provide me with a wiring diagram to start the car from the key?
Sep 14, 2021 at 1:03 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is the information you requested. I've attached below the ignition switch wiring diagram for your Hyundai. I've cut the picture into three pieces so you can view larger. Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 14, 2021 at 1:34 PM
