I need timing marks
2002 NISSAN HARDBODY
475,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
CHRISVDMERWE
  • 7 POSTS
Good day and thank you for the opportunity,
I have a South African Nissan Hardbody 2.0L 16V 2002 Model Model : J03 38
Enj No : KA20016570X
I need to know what the timing should be set to and what the different (5) marks on the pulley means/values. Also should i disconnect anything before setting the timing. I have experience in setting timing and have all the timing equipment.
Any help would be appreciated.
Regards,
Chris v.d Merwe
Jun 10, 2016 at 2:37 AM
HMAC300
  • 48,601 POSTS
we do not have that model here we have a frontier and it is at 18-22BTDC. we do not have a listing for your vehicle and no pictures on timing marks, so this may be totally wrong.
Jun 10, 2016 at 12:13 PM
Can you send a picture of what you need, maybe I can find it that way.
Jun 11, 2016 at 4:21 PM
CHRISVDMERWE
  • 7 POSTS
Hello, thank you here are some pic's.
Jun 12, 2016 at 12:44 AM
CHRISVDMERWE
  • 7 POSTS
Here is a short video hope it helps...
https://youtu.be/ZrS0i3vyIxQ
Regards,
Chris
Jun 12, 2016 at 1:09 AM
MHPAUTOS
  • 31,937 POSTS
A old trick i use on older cars is to set the timing with a vacuum gauge, find the best (highest) manifold vacuum reading by advancing and retarding the ignition, i would be looking at around 5-8deg BTDC make sure all tune items are ok, valve clearances are correct if they are adjustable and do fine adjustment on road test, i will also look into finding the correct setting as well.
Jun 12, 2016 at 3:27 AM
CHRISVDMERWE
  • 7 POSTS
Thank you for your time.
Jun 12, 2016 at 3:49 AM
