Turn single bulb replacement
2007 SATURN AURA
100,312 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JOBAKER
I would like to know how to change a turn single bulb on my car without having to take the hole bumper off.
Feb 13, 2018 at 8:53 AM
Unfortunately, this is what is required in order to remove it because you don't have enough room to remove the bulb without removing the assembly. So to remove the assembly you need to remove the front bumper.
I attached the process from the manual to help out with this.
Here is a guide that will also help in more general terms. Let us know if you have questions. Thanks
https://www.2carpros.com/articles/turn-signal-bulb-replacement
Dec 3, 2020 at 11:34 AM
