Lack of acceleration when the A/C is on
2010 CHEVROLET AVEO
75,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
CHEVYOWNER10
  • 93 POSTS
I am dealing with lack of acceleration when the A/C is on. I would like to do a couple of tests before determining that the mass air flow sensor is bad.
I just replaced spark plugs and air filter. If someone can send me factory info on how to test resistance in a coil pack assembly for this vehicle I would appreciate it. I also would like to know what the fuel pressure readings would be.
I have the tools to get the job finish. I just need the specs and readings I need to have before determining what is bad.
Thanks
Jul 12, 2021 at 3:22 PM
SQM
  • 6,383 POSTS
Is your check engine light on? Any Codes?
Here is a helpful article on low engine power:
https://www.2carpros.com/articles/symptoms-of-low-engine-power
https://youtu.be/U1RoG3I-Oww
I have attached the ignition coil pack testing procedure as well as replacement instructions.
Fuel Pressure Specification: 380 kPa (Battery Voltage: 13.2V)
Thank you.
Jul 13, 2021 at 9:34 AM
CHEVYOWNER10
  • 93 POSTS
No lights. Just notice the lack of acceleration when I step on the gas pedal with the A/C on. I know there’s a full load on the engine when the A/C is running and it’s a hot day out. But when that happened before it turned out to be the mass air flow sensor and I didn’t have any codes. This time I want to make sure before buying a $60.00 part. So that’s why I asked for fuel pressure reading also.
Jul 13, 2021 at 10:14 AM
SQM
  • 6,383 POSTS
Have you tried cleaning the mass air flow sensor? That might help.
https://www.2carpros.com/articles/mass-air-flow-service
If you get a chance to check the fuel pressure, please let me know the outcome.
Let me know if you have any questions.
Thank you.
Jul 13, 2021 at 10:34 AM
CHEVYOWNER10
  • 93 POSTS
Yes, I did try cleaning it but it’s so old it probably wouldn’t do anything. I will check fuel pressure and let you know what I got. Thanks for the info. You are a great help with that.
Jul 13, 2021 at 10:38 AM
SQM
  • 6,383 POSTS
You bet. Let me know if anything else I can do to help.
Jul 13, 2021 at 10:41 AM
CHEVYOWNER10
  • 93 POSTS
Hi, fuel pressure was good. It checked out at 55 PSI and I spray the mass air flow sensor. That seemed to help. So I’ll keep an eye on it.
Jul 31, 2021 at 5:44 AM
SQM
  • 6,383 POSTS
Your fuel pressure is spot on, which is good.
Let me know if you notice something else, will be happy to assist.
Thanks.
Jul 31, 2021 at 8:51 AM
