Bought the car for $600.00, 2 door coupe. owner told me it was overheating due to a burs-ted busted radiator hose, replaced it still overheating. Next I took out the thermostat and it was weakened but still working and the "coolant fluid" that drained when I took the thermostat off was just water, no trace of coolant. Left the thermostat off because it's summer and not getting cold anytime soon, still overheating. The more I ran the car I noticed terrible engine shaking and stuttering so I then wanted to take a look inside. Noticed oil leaking from the valve cover gasket even before starting to take the head off. Once I took the head off I noticed right away one of the valve springs were broken, and the others didn't look too good (blackened/burnt) and some spun when rotating them with my hands. Would it be cheaper to fix the valves and springs myself or to get one from a pick n pull yard? Which would be a safer bet, and easier on my pocket?
Jul 7, 2020 at 4:27 PM
