Okay, I bought this truck from a friend. He had a "mechanic" rebuild the engine, but it took a judge to get it finished after a year of waiting. I bought the truck and within 500 miles it started smoking like a mosquito fogger (only worse, really. ) it is white smoke, but it's also definitely oil smoke. It uses about two quarts of to travel 30 miles. After it warms up most of the smoke either stops or turns black. The black smoke is a very small amount and generally only under power or acceleration. It is not coolant. I don't experience overheating or loss of antifreeze, it just uses as much oil as fuel. The compression is 150 across all cylinders and a couple have built up oil fouling, the rest are actually wet with oil around the threads, but the electrodes are normal looking. I'm hoping that it's either bad valve seals or maybe no oil seals. Someone said oil rings installed upside down, but I'm at a loss. Also, I've heard that there is a tool set that allows you to pressurize the cylinders with compressed air and change valve seals without pulling the heads, which would be ideal. any information or insight would be great! Thanks in advance! I'm a disabled veteran and I am very mechanical, but can't climb around on motors like before, but can do some and can't afford a shop.
May 1, 2019 at 6:12 PM
