i lost the key?
2004 DAIHATSU DUET
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
SENGA
  • 33 POSTS
I have a client who has lost the key to his Duet. need help on how to get the chip from his engine control?
Aug 22, 2022 at 5:49 AM
BORIS K
  • 836 POSTS
This vehicle is also called Daihatsu Sirion on the world market
I can only advise you to program in a new key using CarProg
The immobiliser chip is in the immobiliser module under the steering column.
Usually marked "immobilizer" or "134.2khz"
Remove immobilizer box from vehicle and open box.
Locate 93C66 EEPROM. See image below
Remove EEPROM and read with CarProg using A4 or A5 adapter.
Follow instructions and program in new key
Cheers, Boris
Aug 23, 2022 at 1:42 AM
SENGA
  • 33 POSTS
Where are instructions to follow? how can i get CarProg software?
Aug 23, 2022 at 2:06 AM
BORIS K
  • 836 POSTS
CarProg programmers and software are available online. The instructions will be displayed on screen once using CarProg.
A link for a CarProg retailer:
https://www.obdii365.com/wholesale/carprog-v821.html
As for your initial question I assumed you had experience and equipment to read EEPROMS and to program keys.
You will need to virginise the immobiliser EEPROM and then program key to immobilizer. Once done the ECM will synchronize with the immobilizer again.
My suggestion would be if you have no experience in this to best send it off to a specialist shop.
Cheers, Boris
Aug 23, 2022 at 4:24 AM
