Hello, it sounds like the throttle relearn procedure is not able to complete because of having these codes, they are circuit codes too, so since you have a scan tool can you pull up live data on the Throttle position sensors that are on the throttle body, there could be a connector somewhere that is causing the voltage levels to be off just a little bit. It doesn't take much for the TPS to set codes. As for the Under boost code, wasn't there before the throttle body change, correct? I Don't think the codes will go away until we figure out exactly what your voltage signals are for the throttle body and get that taken care of.
It must be TPS month, this is the 2nd TPS case this week,
So, we need to know what the TPS sensor 1s voltage is at closed throttle, same for tsp 2. The two throttle position sensors go opposite of each other with throttle plate movement. And even a couple hundred milli volts can make a difference.
Circuit Testing is diagrams 8, 9, and 10 below.
This can even be as simple as loose pins in the throttle body connector. Checking that the pins in the connector are tight is extremely important.
I need to add a correct here too, the P2135 is actually the sensors on the gas pedal, the APP sensors correlation. There is a Technical service bulletin on it. I will post it shortly, service info at first had no code listing for 2135 and I'm not sure why, it is a common code. I apologize I should have gone through the TSBs first. But check the sensor on the gas pedal for any water intrusion and I will check for any connectors in series to the ECM that need to be checked. TSB is 10 and 11 below.
Okay, I've added the 2 bulk connectors that the APP sensor (accelerator pedal position) wires run through. The X101 connector is in the engine compartment and the X202 is down on the driver side below the dash behind the kick panel, so where your left foot would be, if you have a sunroof, this area is susceptible to water intrusion if the sunroof drain tubes are clogged. So, check this connector for corrosion with the key Off. Also check the X101 connector for the same. Look deep into the connector pins for any white or green corrosion. The pinout sheet is after each bulk connector picture.
Mar 15, 2023 at 11:51 AM
